I'm curious to know that if an alpine mrp-m1000 (1000watt peak) amplifier will successfully push 2 JBL 15"s (1200watt peak) without any distortion/crackles but still hit hard. Wired to a 2 or 4 ohm load also?
What is the final load of the subs wired together, and RMS of each sub? My mrp 1000 ran hot so i sold it.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Budget?
Try a Fosgate T1000bd, that'll give you in the 750 range at 2 ohms. What are you looking to spend on this amp? Are you wanting to upgrade subs later?
I was after an amp hopefully within the 750-1000 RMS range and price isn't really an issue. Was hoping to stick with Alpine or Vibe Audio if I could if that's of any help.
IIRC the amp you have puts out 1k RMS at 2 ohms....what is the vc config of your subs? 1k to that pair should be fine, could use more, but it'll do.
Edited by siucsaluki11
