Ok so I feel like my system is not getting as low as I want. Could be because I'm running HDC3's and the suspension is tighter than a virgins pussy lol, could be because I'm under powering them badly, could be because of my tuning? I tuned it to 33hz, which I thought would be a frequency. But anyways the best song I've played in my truck as far as demo wise on the lows is Dorrough- Trunk Bang. I wanted to know what the low note was so I threw it in audacity. I took 2 screen shots (1 of the high peak and 1 of the low peak). Are these frequencies correct??
^^^^^The high note in the song is 46hz^^^^^
^^^^^The low note in the song is 31hz^^^^^
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
you tuned the box to 33? wow you really must want to play 25hz on those subs.
once the subs suspension loosens, they'll play better. what is your amps subsonic filter set to?
Audacity is pretty accurate.
Ok cool
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Hell yea I want to be able to get low! To be honest with you I have no idea. I haven't messed with my gains in forever!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Posted (edited)
Yupp 31hz, steering wheel flex even on my 500rms lol
Edited by Baydestrian
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Good call guys! My subsonic filter goes from 10hz-50hz. And it was turned like 90% up!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
