3 sundown 8's what size box?
Yeah you'll be able to fit them. I'm doing 3 SA8 V2s in 1.8 cubes tuned to 32hz. 1.8 cubes is completely doable in your mustang, my sister has a 2001 and she has plenty trunk space. Heres my box for my 8s in case you want to see it.
1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's
C pillar wall @ 29hz
^^^work in progress^^^
How much power do you have and how much power do you plane on putting latter,
I no the newer stangs have a harrow trunk
Youll be able to 6 if you want maybe even 8 if you want to keep any trunk idd go 2-4 of them depending on amp selection
3x dvc2 will give up 1.33ohm and after box rise you should see high 1's, so a good quality 2ohm stable amp will work but a 1ohm will be better
If you ask me for a min 200rms a pop is the lowest idd run but to 750-800 is better
Edited by john253a
thats only 24inches of sub width..and 8 height so roughly 30x10....you have plenty of room height and width to put 3 sa8's in a mustang..
did you plan on having the subs/port sealed forward from the trunk?....you have tons of room..those subs dont take much space to run them
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
I plan on porting them. My orignal plan was to use 2 sa 12s but most people said to do 2 10s or 3 8s but idk will the 8s be able to play the lows? I would love to do the 12s if anyone has and box designs for me. I could even do 1 15" i want SPL so. The dimensions would be 35"w x 10.5"h x 23"L
Why only 10.5 high
And what direction are the subs
Up, back, fwd
Also these think get low,
They are a nasty little sub,
Edit, depending on port and sub location you could do up to 6 in that box, on close to 6k of power,
If you want spl it will come at a price
In cone are 2 of these are = to 1 10 but 1 of these hit hit as hard as a 10 with the lows of a 12,
I can't assist with a drawing as I'm at work but when I get home I can
How much power?
how many do you want to run?
What direction of sub/port?
And what %of sq to spl would you like?
Edited by john253a
  • Who's Online   1 Member, 0 Anonymous, 1367 Guests (See full list)
