Tim Lam Posted July 13, 2012 Report Share Posted July 13, 2012 the doesnt have to be on the same side as the subs... For some that knows alot you design one 1st a 6" side ported box 35"w in max width of 35" is a sealed box with a hole in the side So now the box need to be 29"w to allow fo port So now that, sorted, you'll need more deepth then 19" because you shortened the width by 6" 2nd port length will be somewhere in the 28" length mark so you'll need to bend port so now yourv taken up 12" in the back, putting the port somewhere with 3-5" of sub with the opening facing the rear, and you'll have unloading issues with the port facing 1 or 2 subs 3rd to stop unloading you'll need to put 2x bends to make it 180deg, and then you lose the efficiency of an aero, witch is what allows you to use a smaller ratio Gimme demensions of the trunk, i'll design you one:]. you just stated a lot of assumptions there just saying. we dont even know the demensions of the space hes putting it in to Quote Link to comment Share on other sites More sharing options...
john253a Posted July 13, 2012 Report Share Posted July 13, 2012 fuck man cant you even read, he's alrady posted them, and the car there going in Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 13, 2012 Report Share Posted July 13, 2012 Gimme demensions of the trunk, i'll design you one:]. you just stated a lot of assumptions there just saying. we dont even know the demensions of the space hes putting it in to OP posts his dimensions in another thread: 35"w x 11"h x 24"L. Quote Link to comment Share on other sites More sharing options...
john253a Posted July 13, 2012 Report Share Posted July 13, 2012 (edited) and with the 00-04 mustang im pretty sure 11" doesnt fit hard up against the rear of back seat the roof need to tapered if you go over 10.5 from memory it goes up to 14" at 9-10" out, i havent done a mustang box for a while as there not to common over here edit another thing to consider, most of these boxes will need to built in car, i think 15-17" in deepth is the biggest you can fit, if constructed out side of car Edited July 13, 2012 by john253a Quote Link to comment Share on other sites More sharing options...
Tim Lam Posted July 14, 2012 Report Share Posted July 14, 2012 fuck man cant you even read, he's alrady posted them, and the car there going in you're real cool. Gimme demensions of the trunk, i'll design you one:]. you just stated a lot of assumptions there just saying. we dont even know the demensions of the space hes putting it in to OP posts his dimensions in another thread: 35"w x 11"h x 24"L. thanks mang. Quote Link to comment Share on other sites More sharing options...
