Had one a few yrs ago at the shop I was at do this. Had to do with the security system. Try hooking factory unit back in, disconnect battery for 30 secs to reset computer and security and see if that works. Also double check your main battery fuse and or relay.
It has a alarm that uses the factory remote already installed when I bought it
2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
Yup tried everything even left it unhooked for about 30-45 minutes while I ate dinner clicked on and off acted like it was gonna work and went back to not working
Sounds like you smoked the LAN system.
What works in the truck?
When you turn the key to ign do lights on the dash come on?
Does it crank over?
Headlights work?
You say clicks and crackles...???
Try to be more accurate with what is going on
Is it cranking over?
Is it trying to?
If not, either jump start it or put a charger on it.
Doesn't crank or anything absolutely nothing works..... the the negative post on my bat gets hot quick even if I don't do anything to it the only thing that works is the stupid blue led from the alarm every once in a while the interior lights turn on like it's gonna work then turn off sux im gonna have to wait till I get back from work in 6 or 7 days gotta get up in a few hours and head out thanks for all the help and suggestions.......when I turn the key it makes a humming noise that's about it
No dash lights come on at all
