port question
alright i was thinking about building a box, and my question is "when the port length is longer then the box is that when it needs to be a L?"
hope i put that right for you to understand, if not i will upload some pictures
Yes.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Yes. just make sure your L port is just as wide as the rest of the port. for instance, if it's 4" wide, make sure you start the L exacly 4" from the back wall of the box.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Post the sub,amp,vehicle models and max dims for a box, type of music also and myself or others will issue a suggestion, there is also a tutorial to answer all your questions in case you want to do it yourself:
http://www.stevemeadedesigns.com/board/topic/145174-ported-box-design-a-tutorial-updated-630/
Ok here is a suggestion:
Enclosure Specifications:
Fb = 35 Hz
Vb = 4 ft^3
External Height = 14 in
External Width = 36.25 in
External Depth = 22 in
Port Width = 4 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 36 1/4 x 14
Left & Right Sides = 20 1/2 x 12 1/2
Top & Bottom = 36 1/4 x 20 1/2
L Port Internal Assembly Parts:
Front to Back = 15 3/4 x 12 1/2
Extension = 2 x 12 1/2
Assembly guide of generic dimensions:
  • Who's Online   0 Members, 0 Anonymous, 653 Guests (See full list)
