cobalt has no alt postive bolt?
There is no positive bolt on the cobalt lt coupe 2010. There is a harness that is wired to the alt and attached to a bolt by the fuse box where the alt to battery stock wire is. What should I do? Trying to do the big 3
2010 Cobalt LT Coupe
Subs: 2 American bass XFL 12s
Amp: Crescendo BC3500D
Big 3 in 1/0awg
29hz box
stinger volt meter
2nd battery Deka 9a31
pioneer DEH-9400BH
How is the harness attached to the alt? How big is the wire ?
Normally an alt will have both a harness that plugs into the voltage regulator AND a bolt terminal that is. The positive output.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
How much does the stock alternator output on your Cobalt? I'd assume there is a alt-positive, but if not, you may have to splice. However, the stock harness and that connector aren't designed for high outputs, I'm assuming.
Alpine CDE-164BT/Rockford Fosgate P400X4
Kicker CS 6.5" Components (Front)
Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage)
RF P400X1 Monoblock
2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box.
its 105amps and the harness goes directly into the alt and attached to a bolt 3 feet away
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
  • Who's Online   0 Members, 0 Anonymous, 1653 Guests (See full list)
