Suddenly popping inline 40a fuses.
I have a Rockford 600.1 amp that has 2 30a fuses on the side.
For the last 3 weeks I have been playing my system pretty hard and everything has been fine. It was tuned with a DD-1.
Now all of the sudden today I have blown my 40a inline fuse running off my battery. I replaced it with another 40a fuse and 5 minutes later it popped again. Why? What should I do?
The only thing that changed was that my battery died and I jumped started it at a Jeep show I was at today. But it blew about 2 hours after that.
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
you have a 40 amp fuse on an amp that has 60 amps worth of fusing. put a 60 amp fuse in the inline fuse holder
what size wire are u using?
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
I understand the logic and all but why has it been fine for the last 3 weeks but today it acted up? Im running 4ga wire
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
I dont mind upping the wire or the fuse ratting if everything else is fine. But why all of the sudden?
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
maybe some strands of wire came loose. check ALL connection points. from the battery all the way to the amp terminals.
I have and everything seems fine. Should I just go ahead and up the fuse to a 60? Its not like the fuse is popping instantly it is taking a few minutes at full power but I keep going back to it was fine for the last 3 weeks.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
What size is the wire? derp
Just use a bigger fuse.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
