Daniel Shepard Posted July 22, 2012 Report Posted July 22, 2012 Both of these were for a re se 15 in a std cab s10 4.5 cubes@32hrz , two clicks up on seat This one is sealed @2.5 cubes, one click up on seat, foam removed in middle
CleanSierra Posted July 22, 2012 Report Posted July 22, 2012 No way that box is 4.5 cubes net. I'd like the measurements. Is the port firing RIGHT at the B-pillar? Seems like it would be choked as hell. Not trying to hate, I'm Just confused at what I'm seeing. Im not the one you want to try to troll. Just a fyi for you.
Daniel Shepard Posted July 23, 2012 Report Posted July 23, 2012 No way that box is 4.5 cubes net. I'd like the measurements. Is the port firing RIGHT at the B-pillar? Seems like it would be choked as hell. Not trying to hate, I'm Just confused at what I'm seeing. Hence why you dont see a installed picture! it sounded amazing but wouldnt fit haha. Im not sure what the dimentions were, slept since then. but 26" tall, something like 10=12 deep on bottom, 4 on top, 56-59 wide? Its been a while since I built that. It was way under powered off those memphis amps. I may be off on the ft3, your right, I would have to dig my drawings out of the attic and double check. the port accually cleared the b piller, but was firing at the door haha. I shortened the total port length to make up for that a bit
SixTwoRado Posted October 17, 2012 Report Posted October 17, 2012 My trucks a single cab kinda I use to have a RE SE 10 behind the seat, I loved it. 1.25cu/ft at 28hz. First box ever was a angled box, ran it on a MB Quart ONYX 1500 @ 2ohm http://sphotos-a.xx....6_2272803_n.jpg http://sphotos-b.xx....53_492720_n.jpg http://sphotos-a.xx....1_1717727_n.jpg Were the wires are is were I put the 3inch areo port. Did you ever have any port noise with this setup? Im trying to design a box for a SA 12 in my king cab frontier. I want to use an aeroport because of my space restiriction and trying to leave to other passenger jump seat open in the back. No matter what I cant figure out an aeroport setup that has any more than like 7 inches squared of port area. And Im getting rediculous rear port air velocities in winisd. Do you think I could pull off a single SA-12 with a 4" aeroport, about 1.8 cubes tuned around 34hz? Here is a pic of my basic box design I came up with. Has the tuning and air requirement after displacement but not enough port area. And the second pic is of my current sealed box and the space I have to work with. Im going to remove that jump seat in order to get more room for the bigger ported box.
cmw5e Posted October 17, 2012 Report Posted October 17, 2012 No way that box is 4.5 cubes net. I'd like the measurements. Is the port firing RIGHT at the B-pillar? Seems like it would be choked as hell. Not trying to hate, I'm Just confused at what I'm seeing. i know in my f150 i can only get around 2.5. i know chevys can go a little longer and a little taller but seems like the fords have a chance to be a little deeper. i dont see 4.5
