Okay this is my problem, I ride around for awhile bump my shit or w.e normal stuff, then I went home today parked my car forgot something car won't start im like wtf?! Check my battery's and there all at 12.98 what could it be??
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
check the negative terminal on your battery, it was a big problem when i first got my mustang
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
all connections are good I checked them all, since I have custom terminals on all my battery's upfront and the back 2 d3100s
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
What happens when you turn the key? Nothing or does it crank but not start? I've been having problems with my 02 the theft light randomly comes on and blinks when I try to start it, it'll crank but won't start. The only way I can start it when that happens is to use my remote start which is kind of embarrassing in a busy parching lot or gas station.
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Idk it all started when I had my wall up and running ill go full tilt on it and the odometer on my car will go on and off, but my headlight won't dim or nothing amp staying on everything expect for that makes me Think it's a electrical related to me car issue no idea
And it doesn't even crank which is crazy since I will shut off my car and turn on when im waiting for my turn to go into the lanes I even did a friendly 49.9 class of bass race and we tied 3times before a db drag i went to and my car was off and after that it still turned on no issue but i got home parked it turn it on for a cd boom no crank no power no nothing
Edited by KnockinthaStreetzof608
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
maybe somethin shit out on you somewhere? ummm, a short in wiring, blown fuse, bad alt/battery, bad grounds, could be a lot of things, or maybe more than 1 thing all acting together to really pissss a person off
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
but wouldn't I have ran into those issues when I was demoing or competing in the lanes? Idk I checked every looks good, got my terminals super tight now and left my charger on my battery's car turns on again so im going let them float charge for the night, just weird on how many times i turn it on and off and nothing weird happen and i get home turn it off then turn it on nothing,
I'm confused who did i piss off? Lol
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   0 Members, 0 Anonymous, 2039 Guests (See full list)
