viper1315 Posted July 17, 2012 Author Report Share Posted July 17, 2012 The subs would have enough room i believe because my bottom length where they will be mounted will be 13 inches possibly more and the top of the box i want to be 3 to 4 inches where i want the port to come out my max across will be 60 inches and where the tranny comes up the bend in the back of my seats i am going to go around and then all the way back down to the floor again. 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue. Link to comment Share on other sites More sharing options...
CleanSierra Posted July 17, 2012 Report Share Posted July 17, 2012 That should work pretty well, but you'll have more volume than you need if you go that far to the floor and that high up the back of the cab. You don't want too much air to those subs. You also won't be able to measure the volume of that weird area of the floor hump region, until you've made some kind of fiberglass shell and filled it with packing peanuts(easy way to check volume) to see what you have to work with right there. You should only need about 2 cubes net for those subs, not 3-3.5 like you will likely have if you use all the space you're referring to. I'm just trying to help, and I have the behind the seats measurements memorized I've crunched so many numbers for boxes back there. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
viper1315 Posted July 17, 2012 Author Report Share Posted July 17, 2012 That should work pretty well, but you'll have more volume than you need if you go that far to the floor and that high up the back of the cab. You don't want too much air to those subs. You also won't be able to measure the volume of that weird area of the floor hump region, until you've made some kind of fiberglass shell and filled it with packing peanuts(easy way to check volume) to see what you have to work with right there. You should only need about 2 cubes net for those subs, not 3-3.5 like you will likely have if you use all the space you're referring to. I'm just trying to help, and I have the behind the seats measurements memorized I've crunched so many numbers for boxes back there. so do you think i should just ignore the hump and run the box normal without it going way down there or go down and cut the top shorter? 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue. Link to comment Share on other sites More sharing options...
CleanSierra Posted July 17, 2012 Report Share Posted July 17, 2012 I think you should run the VOLUME of the box above the hump, but trim the box all the way to the floor. That's what I did to make it look clean. I ran my port differently than you are planning on though. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
soundbybass Posted July 17, 2012 Report Share Posted July 17, 2012 Porting into the side of the truck is good but only if it has 3-4" of room before the panel otherwise you will choke it Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row Link to comment Share on other sites More sharing options...
viper1315 Posted July 17, 2012 Author Report Share Posted July 17, 2012 where do you guys think i should run the port then? 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue. Link to comment Share on other sites More sharing options...
viper1315 Posted July 21, 2012 Author Report Share Posted July 21, 2012 Just Installed my new stinger voltmeter at 3AM last night and a dead battery 2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build 2001 GMC Sierra XSPower D3400 Pioneer AVHD 1400 MB Quart Component Sets Pioneer 5x4s Audiotechnix Power Wire, Speaker Wire, Sound Deadener DC Audio Level 4 10s DC Audio 3.5k Rocford Fosgate R400-4 HID 6k Slammed Truck on 20s Candy Blue. Link to comment Share on other sites More sharing options...
brandon9491 Posted July 21, 2012 Report Share Posted July 21, 2012 looks good, u got the 5.3L? you should do a big 3 tutorial if you do Link to comment Share on other sites More sharing options...
Miles Posted July 21, 2012 Report Share Posted July 21, 2012 You can get 2.5 cubes net comfortably behind the seats. You'll have to build a step in the back of the box to go up to 18-20" since the highest you can go without a step is 13.5". Link to comment Share on other sites More sharing options...
soundbybass Posted July 21, 2012 Report Share Posted July 21, 2012 Port out the side Probly passenger side so you don't ever hear the port noise if there is any Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row Link to comment Share on other sites More sharing options...
