SMZ2's Xterror. 1st Hairtrick!
Damn man good job so far. I may have to stop by and see it one day. Lookin forward to that video also
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
Thanks man. Maybe I can stop by tomorrow man after class I should have time.
I've been listening to it today and the only thing that is bothering me is that there is a lot of flex from the thin strip of wood at the top of the port and it is buzzing like crazy with this said I don't think I'll be able to pull of the lexan idea I had so I think I'm going to save for another sheet of mdf and double the top of the box and brace the heck out it. Hopefully all that add there should be any more flex issues or buzzing from the box just the xterra haha. So no more lexan I'm going to do something that I know will work instead.
you probably could do some vertical bracing with threaded rod. you'd have to pull it out again haha, but there is a way you can do that. put the threaded rod off to the sides so it still allows you to move around in the box. You'll have to put 3/4" thick block of wood on the bottom so you can make everything flush on the outside. I'll sketch it up if you need me to.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I have some aluminium angles I made also for bracing the top. Do you think I should still double up the top? I want to if it will help. I still have to take it out to paint anyway and the cover for the old port is temporary until I get some more mdf. I also have to make a frame for the box etc so I planned on taking it out haha. Can you sketch it up please?
when are you gonna bring it by the shop again to run?? i might be able to help you out with the bracing issues also man
Brandon? I will soon hopefully I'm just really broke right now haha. Part time hours suck and my current job is like a 30 minute drive. If you know anybody looking for somebody part time let me know.
Doubling up the top definitely wouldn't hurt, I don't know that it would be entirely necessary though. I've got the pictures uploaded, let me just post them and explain them real quick.
More box builds
Okay thanks man it flexes really bad that is all I have to say haha. Plus Ill have to do the double baffle for the reason of sealing the old port I think I will drop the lexan idea haha. The current way its sealed is just temporary its only spray foam and screws I was just tired of not having beat...
I get my license back in exactly one month, and one of the first things I plan on doing is hearing this beast! :D
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 2192 Guests (See full list)
