Okay. So while driving to class today, my amp decided to take a shit. Only this time it was permanent. I pop the trunk, the amp is burning hot to the touch and I smell burning wire. Anyone have a guess as to why? All the wires were connected properly. No arcing. It wasn't hot in the trunk. -Exact amp is in the sig-
1999 Honda Civic- RIP
2003 Acura RSX Type-S
i would take the back off and have a look . i would expect to find a burnt mosfet or a toasted transformer
It's getting replaced Monday as long as the warranty seal on the casing is still intact. Soo that's a no-go. But what do you think would cause that to happen?
Did you have it grounded correctly?
Yeah, it's grounded to a sanded down section of frame.
Edited by CDetty
These are the questions that you are going to see if anyone else responds.
1. Are you grounds good?
2. What is your voltage full tilt and when it fried?
3. What is the ohm load the amp is seeing
4. Have you done the big 3?
5. How is the amp mounted
6. Were you clipping, are you sure, are you really sure?
7. How did you set your gains?
8. Bass boost?
9. Eq settings?
10. Were you clipping?
11. What was your voltage?
edit.
i forgot one
12. What alt do you have?
Edited by strangeduck
i really can't answer you why an amp might fail because i don't know enough about how an amp works to break it down , shorted mosfets is a common failure of amps , so is the power supply . assuming your install was good and all settings were good you may have just gotten a dud . but i would really suggest that you double check every thing before too long when you get your replacement amp . i would also recommend a voltage meter , when your voltage dips playing full tilt your amp has to work alot harder and low voltage can make an amp very unhappy
It does bother me that you said it "took a shit on me , only this time it was permanent" I would guess the amp has been treated like a red headed step child and just committed suicide.
8. Bass boost?
9. Eq settings?
edit.
i forgot one
^^^should be set to autopost whenever this question comes up
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Like a inexpensive Peruvian hooker,.. It can and will go both ways. And both ways easy.
I've seen the most intelligent active members lose a amplifier here.. Made me sick for them.. Sometimes, it does truly "just happen" .
Also, I've seen/read a dumb ass asking how to wire lower than .5 ohm,... After reading his profile of "stock electrical" and still jamming...
I can say you lost it because, BUT, it has been fine up untill now why????..
Man... Sometimes IT REALLY does just happen ...
Sorry for the bullshit post, & no help....
Bad grounds, bad voltage, clipped signal, to name a few. More details of your setup, as previously mentioned, will be needed to help you figure out your problem. The comment you made about "this time for good" has me concerned as well. What have you done to it previously that it's been fucking up on you?
