gotb00st Posted July 19, 2012 Report Posted July 19, 2012 I just got a quote from Mike Singer on a 260A H/O alt for my 02' Envoy he stated its the largest he has for the vehicle. I'm unable to run a dual alt setup in my vehicle due to the lack of space with the I6. Here is my current build list: Sub stage 2x FI Sp4 12s or 15s (depending on space) DC 5k amp (running at .5 or 1 ohms) Singer 260A alt XS D3400 under the hood 2x XS D2400s in the rear Front Stage 2x Alpine SPR-60 in the rear doors 2x Alpine SPR-60c components up front Alpine MRX-F65 Amp Wiring Big 3 Upgrade 2x runs of KnuKoncepts 1/0 Kolossus Fleks Kabel for the rear KnuKoncepts KCA 8ga for the front stage 2x Stinger 6000 series RCA's Stinger voltmeter With this setup will I have the proper electrical to maintain voltage for daily use? I listen to allot of dubstep, chopped/screwed, hip hop, and some rock.
AMI CUSTOMS Posted July 19, 2012 Report Posted July 19, 2012 At 1 ohm yes but .5 ohm you would have some voltage drop into the 11s. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
gotb00st Posted July 19, 2012 Author Report Posted July 19, 2012 So if I did decide to run at .5 ohms would maybe another D2400 compensate for this voltage drop? Or would that be to much strain on the alternator to keep up? Another note I'd like to add is I prob wont be running full tilt most of the time. I would just like to have the reserve if I did decide to.
Bump4life Posted July 19, 2012 Report Posted July 19, 2012 how does one know exactly what the voltage drop would be? I say it sounds like it should be ample. instal it and leave room or the option to add another batt if you need. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Mr.JaunDurfle Posted July 19, 2012 Report Posted July 19, 2012 Why not go with the XP 3000's? More AH and RC. They are down a little in Max amps, but if you are going to do multiple batteries, which you will need to do, I think the XP's would be better. They are supposed to be better for everyday music listening anyway. With my re-build I'll have a Singer 350A alt, one Yellow Top, 4 XP 3000's, all 1/0 gauge wire and a DC 5.0K wired to .5 ohms nominal. I might have some voltage drop, but shouldn't be much. 2001 VW Passat Sportwagen Alpine ICS-X7HD DC Audio 5K SSA 15" XCON Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS Incriminator Audio IA6.4 XS batteries, KnuKonceptz wirez, Second Skin
gotb00st Posted July 19, 2012 Author Report Posted July 19, 2012 Thanks for the advice, I completely overlooked the xp series batteries. My main concern is a 260a alt wont be able to keep up with the 5k even with plenty of reserve I feel its going to get hot and overworked.
Mr.JaunDurfle Posted July 19, 2012 Report Posted July 19, 2012 If you put a charger on your batteries every couple of days, you'll help your alt out alot. You should be okay with a 260A alt. 2001 VW Passat Sportwagen Alpine ICS-X7HD DC Audio 5K SSA 15" XCON Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS Incriminator Audio IA6.4 XS batteries, KnuKonceptz wirez, Second Skin
Socky Posted July 19, 2012 Report Posted July 19, 2012 dc derrick ran like 200 amp alt and i think 1, 1400,4 hc2400s and it could hardly maintain in the 12s on a stetsom 7k. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
RAM5493 Posted July 19, 2012 Report Posted July 19, 2012 If you put a charger on your batteries every couple of days, you'll help your alt out alot. You should be okay with a 260A alt. I didn't know it helped like that. So if i get a charger it will reduce the work on my alternator? also is it only if you're running multiple batts besides the primary? I can plug it every night if thats the case
mrd6 Posted July 19, 2012 Report Posted July 19, 2012 I second replacing the 2400s with the xp series and then would say pretty much the same as AMI My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
