The back of my cab flexes in and out about .25in each direction and was wondering what people without full walls do to prevent it? (moves the closest wall of the bed too)
also, the side of the inside of my cab flexes and it is opposite the port side and it had deadener and padding behind it yet still seems to make noise, what would be the best fix besides total panel removal?
Edited by ChevyBoy95
better quality or more deadener
no. back wall has more than enough to the point of wasting it. edit, and it is 80mil. the sheet metal itself is moving and causing the noise more than anything, almost like a flapping sound, on my peakier notes.
2x4s
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Pl adhesive if you can flex a solid wall of 2x4s attached to the sheet metal you're doing something serious
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What N8 said, depending on what truck you have, you May have enough room for a layer behind the box and it will make the back wall "flush" with the window frame delio
I have 2 layers of 2x4 and 1 maybe 2 layers of MDF for my back wall... And im waiting for my back window to fall out lol... Fix the back wall flex before you break the window free
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i heard a bunch of tennis balls shoved between the cab and the bed works pretty well.
tried that with a weaker system.... didnt do shit.
guess ill go the MDF/2x4 route, i have about 2in from the bump below the back window to where the back of the cab below is.
again, what is the best way to attach it?
Pl construction adhesive comes in a caulk tube
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1840 Guests (See full list)
