Box design for Dodge Ram
Sure:
Enclosure Specifications:
Fb = 34.8 Hz
Vb = 4 ft^3
External Height = 19 in
External Width = 39 in
External Depth = 15 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 39 x 15
Left & Right Sides = 13 1/2 x 17 1/2
Front & Back = 39 x 17 1/2
L Port Internal Assembly Parts:
Top to Bottom = 13 1/4 x 13 1/2
Extension = 4 x 13 1/2
Everyone has their favorite and that's all right, but don't count out the first one, ask around before cutting any wood. There are a few interesting threads on the topic.
Thanks for the designs!
45 corners?
Router edge of port?
Of course!
Should put anything on the inside of the box or the port like resin or idk something?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Loudest setup in that truck probably won't be a box designed like that one. Port up subs up is where I would start.
i had a 99 dodge 1500 ext cab...................subs forward port up sounded better to the ear. ive had subs up and port up.....was a louder to the ear but lows didnt sound good...ive had subs up and port drivers side and that sounded decent........but i believe its just a personnal prefernce.
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
I found some threads about 45s actually lowering db's should I not do any 45s ?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
In the second box a 45 on the port turn (as shown) is good, made the first box transparent for you to see what's inside, check the crossbraces shown on both boxes.
Cross brace is 2" wood dowel?
Should I recess the wooden dowel into the box?
Should I line port or box walls with anything?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
damn why is it so complicated to upload pics.?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
  • 2 months later...
Sure:
Fb = 34.8 Hz
Vb = 4 ft^3
Cut Sheet List:
Like this? Its a 2nd option I was given. Might be a option I,ve often thought about it.. You actually were the reason I asked for it but the first one was a bit simpler to assemble.
And when I step to 18s won't I have to do subs forward with port forward above them, in almost a whole wall?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
Rockford P400-4
2 Polk DB 5 1/4
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
