Amp quit working need help
Astranomical
today my amp started making a weird hi pitched noise so i shut my car off for acouple hours then went to turn the car back on and it makes a high pitched noise for like 3 seconds then the amp goes right into protect mode. It is a sax1200d im running stock electrical with 0 gauge rf wire. Does anyone have any idea what this could be was going to enter my first competition in august and now my amp is shot i think.
Well the buzzing noise went away but i turn my deck up to 34/62 and my amp started to smoke so i took my amp apart img0171rg.jpgimg0172hy.jpg
if you notice in the first picture there is a little blue box underneath the silver wire with something that looks like popcorn i dont know what that is
Eat the popcorn, make sure you have adequate power to the amp, get a new amp.
Seriously though....
You need to tell more about your setup, what subz, what ohm load, how is you amp wired - where is the run of 1/0 going? DO you have big 3 done. Are your gains set properly (define how). How hard do you clip your amp. etc...
Edited for spelling, mistype.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i have it running 2ohm to 1 15 no big 3 gain is set low like quarter of the way up dont have a dd-1 so i cant set properly and honoestly i have no idea if i clip it or not how do i check that. the 0 gauge is ran underneath my car to my positive access not on the battery. i run my deck on 57/62 bass knob is always turned to 3/4 the way turnt up
How long did you had the amp running for and did you give it an air for it to breathe.. SUndown amp are power hungry..
how bad was voltage drop? did you ever watch it?
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
