Subwoofer options/Limited space for ground pounding bass
Spent about 30 seconds vaguely crunching number in the Torres calc. You can fit two Sundown SA-15"s if you wanted to.
If I were you idd be ashamed submitting that design for someone to build
First
2x 6" ports us not enough port for 2x sa15"
Second
17" long is 18" overall that leaves you with 3.25" of clearance between the back of box and port
Third
Where does the port go out to, a wall (max 22")
A blocked port is no different to a sealed box that leaks (I already asked him if there was clearance for port at 22")
Forth
2x sa15" in a box with no bracing, how long is that going to last
If I were you idd spend a bit more time learning and less time braging about how long it took to through something up
2 18" obsidians very efficient woofers...
Thanks for the info. Never heard of the brand but did some research and they seem to be as you have stated. Thanks!!!
Have you got even half a brain
He barly has enough space for 2x 12
And can't even fit 2x 15 so how the fuck will 2x 18 fit
Well first off he can fit 2 15's as i own a 2007 escape with 2 aq 15's
Now OP your box could be bigger like WxHxD 40x22.75x24.5 thats the dimensions of mine. That is the whole cargo area and i have an extra battery with 3 amps there. You could even go 41 on the width
Wow dbag you serious? First off i own an escape and i have 6.6 cube box for 2 15's easily fitted in there and its below the seats. Obsidians are just like the sundowns sa's they love small box's. watch me put a street legal 2 18 box in my escape smart guy you must know everything oh yea apparently not...
Youtube.com/J Hutch22
If ya want to sacrifice your spare tire well you can place your batts in there and also you will see a good sized drain plug that you can fit about 4 runs of 1/0 through
straight from the obsidian site
Ported ~ 4 to 6 ft^3 @ 28 to 32 Hz
small boxes my ass. he doesnt have space for 18's. enough fucking said.
1 sub foward 1 sub up external aeros to the side or back and manufactures specs dont mean shit enough fucking said.
I have a 2007 Ford Escape and wife will only let me use hatch space. .
Yes he has more space, but with the meserment given and what he is aloud to use he ain't fitting them In.
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
