What is the best way or correct way I should say, to debadge my Bravada without peeling up the paint?? Thanks guys in advance!!
i used a hair dryer and some fishing line to debadge my jetta
Mk4 jetta 2 point slow
Kenwood KDC-X496
hifonics HFI-1000d
Obsidian 12 in a 2 cube box 34hz
some shitty orion 4 channel
2 pairs of infinty components
youll need something to heat the glue up, that way it will be easier to remove, do like the guy above did and try some fishing line. Be slow and careful cant rush it or else to wont remove all the glue.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Gasoline works great to get residue off, just don't leave it sit on the paint for a long time.
What about Goo Gone? Wouldnt that help with the residue?
i was just going to add use some goo gone or soemthing similar to get rid of residue and then wash and wax to make it look pretty
Kenwood KDC-X496
hifonics HFI-1000d
FIshingline is too thick. I have used Dental Floss for 20+ yrs. Let the car sit out in the sun and you can slice it right off. Dish detergent will remove the glue without messing up your finish.
How old is the car, if its a little older it might be faded where the badges are, and when you take them off it will be a different color under it.
Good luck
Skip
Does this smell funny to you? Its your sister :roflmao:
Good luck
Skip
Thanks for the info Skip. Its a 2001 Oldsmobile Bravada and ill try floss as well!
  • Who's Online   0 Members, 1 Anonymous, 2806 Guests (See full list)
