Alright guys I have another question that's gonna make me look like a car audio noob.
My Dad likes me to explain everything I do to my system and the reason why I'm doing it. I was explaining the Big 3 and he wants to know why you run a power wire from the positive of the battery to the alternator. I couldn't even answer it.
If you could tell me why please do.
Thanx
2006 Ford F150 4.6 3v
(2) Digital Deisgns 3515's D4
Digital Designs M3B w/ Toolmaker Dual Inputs
Mike Singer Built 340 Amp Alternator
Arc Audio KS 300.4
*mids and highs to come soon*
Alpine 148BT
And tons of 0 AWG
So that the alternator can charge the battery. That's the simplest answer.
HU: Kenwood Excelon KDC-X791
Fronts: Image Dynamics CTX65CS
Rears: Image Dynamics CTX69
Subs: 2, 12" Boston Acoustics G5 w/ GTR passive radiators
4-channel amp: MB Quart ONX4.125
Sub amp: Kicker ZX750.1 ('07 model, 926 watts RMS @ 2ohms rated)
1/0 awg Rockford Fosgate & KnuKonceptz wiring all around
XS Power D5100R main battery
Coming soon: Mechman 220 amp alternator & Sundown Audio 125.4
Because the battery gets its power from the alt...
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
i would explain it more as running the positive on the alt to the battery.... that way the battery gets power DIRECTLY from the alt as opposed to going through anything else.... plus thicker wire = more current = :morepower1:
Thank you!
Arc Audio KS 300.4
Alpine 148BT
And tons of 0 AWG
Thank you!
it also improves voltage, which is the biggest reason why people do it I think. That's why I did it anyway
That is an even better way to put it.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
Thank you!
I'm about to install a volt meter so I can watch I voltage but I see a lot of people running 14 volts is that necessarily good?
Arc Audio KS 300.4
Alpine 148BT
And tons of 0 AWG
Thank you!
yes that is good. if it's sitting around 14v while playing then you have a good system. You want to start getting worried when it's dropping below 12v. Amps like to operate at higher voltages, if you drop down too low then your amp will go into protect which is bad.
  • Who's Online   0 Members, 0 Anonymous, 448 Guests (See full list)
