TRON Posted July 24, 2012 Report Posted July 24, 2012 I've got a new build coming soon and I need to figure out amps. There's probably going to a few AA Meyhems, maybe 4. I was thinking something like a Sundown SAZ-2500D or Crescendo BC2000D per driver, but those are the only amps I can think of. I'm sure that a meyhem can take more current but i want to start off at the RMS. Whats the best way to power those divers? One amp per coil or a bigger amp per two coils? Power supply with be...abundant, so Im not worried about that. keep it a 14 volts too. I know I'm probably sounding like an idiot for asking. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
AA98hoe Posted July 24, 2012 Report Posted July 24, 2012 i use 2 dc 7.5s for 4 mayhems,,,clamped 17,800watts...an they can take more TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
OrionStang Posted July 24, 2012 Report Posted July 24, 2012 3500 per sub, sweet spot. SMD Super Seller My Feedback Thread
TRON Posted July 24, 2012 Author Report Posted July 24, 2012 i use 2 dc 7.5s for 4 mayhems,,,clamped 17,800watts...an they can take more Dual 1 or dual 2 coils? Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
cosmo10292 Posted July 24, 2012 Report Posted July 24, 2012 get the new dc 10K!!! 2500RMS per sub if you go 4
TeamHT Posted July 24, 2012 Report Posted July 24, 2012 I definitely love around 3,700 per. Tell me...does this smell like chloroform to you?
AA98hoe Posted July 26, 2012 Report Posted July 26, 2012 i use 2 dc 7.5s for 4 mayhems,,,clamped 17,800watts...an they can take more Dual 1 or dual 2 coils? d2s which are 1.4s each amp at .35 daily TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
TRON Posted July 26, 2012 Author Report Posted July 26, 2012 Those amps are stable at .35 then? Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
