Music gets louder when I hit bumps
Adnan
I've been having this issue for a few days now but every time I hit a pothole or take a corner my subs get noticeably louder and then slowly back off,I have 2 15" RE SEs powered by an ED nine.1 @1ohm using 0ga wiring
Any thoughts?
Bad ground loose somewhere.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
well I checked my connections a couple of times,nothing seems out of the ordinary but im gonna double check my ground in the morning and make try another grounding point
thanks
Did you sand the ground?
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
it could be a bad power or ground.
im more leaning towards a bad rca cable. maybe not visible but there could be a short or bad connection inside one of the rca plugs.
it could even be the rca board inside your amp that may have broken loose and needs to be resoldered to the amps pcboard.
