Just wondering what it would take to convert my car over to projectors.
I already have the kit from DDM w/ h4 bulbs. So I guess all I would need are some lenses right?
If I were to get something like this, would I just have to bolt it in and install my current HIDs or is there more to it?
http://www.ebay.com/itm/NEW-CAR-MOTOR-AUTO-VEHILE-2-5-HID-BI-XENON-HEADLIGHT-PROJECTOR-LENS-LEN-H4-/290716474285?pt=Motors_Car_Truck_Parts_Accessories&hash=item43b00d5bad&vxp=mtr#ht_7912wt_1163
I dont know what car are these going into, but with those lenses probably your lighting pattern would suck.
I've heard these are awesome, and the pattern its superb.
http://www.ebay.com/itm/MORIMOTO-MINI-H1-4-1-BIXENON-PROJECTORS-CLEAR-LENS-HID-H7-H4-RETROFITS-LHD-/260956326682?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc2358b1a&vxp=mtr
audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
Posted (edited)
Car is an '03 Forester. Uses h4 bulbs
Edited by SnowDrifter
forester? it should be a fairly simple retrofit.
let me know how it turns out if you do it.
look for morimoto retrofit in youtube, there are plenty of videos!
Ok sweet thanks
There are a few things I am wondering about this though..
How do I secure the projectors in the stock housing? Do they bolt right in / do I have to glue them in / make my own holes
And how do I make sure they are level?
Beyond that, just stick the bulb in and go?
P.s. Does any one know of a 5000k h4 bulb that is both good and will fit the ddm ballasts?
Ok sweet thanks
Yes you do have to cut and glue or somehow secure the projector in place of the housing
For aiming it would be. Park about 50 feet of a wall and try to get ge horizon line whereyou feel it dosent blind anyone amd is perfectly even with the other one. So the light beam should be like this - and not like this/ lol
As for bulbs, i can say just try to order the ddm ones. Just make sure of your ballast os 55 watt to match it with a 55 watt bulbs and, and so on for the 35 watts
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
Email the retro fit source and they can answer any questions you have. To answer your question about what holds the projector to your headlight there is a threaded end on the back of it and you get a nut and screw it on mad that's how it is attached.
2011 Chevy Camaro
Pioneer AVH-P1400
AA Mayhem 12
Audioque 3500D.1
Knu 1/0
2000 Chevy Silverado
2 Sundown SA-15's
1 American Bass 200.1
Sky High 1/0
Stock Electrical..... FTL!
Posted (edited)
get the morimoto mini they are very good i did them on my 2005 kia spectra5 about a year ago you just pull the headlight lense off i used a heat gun to heat the glue up. they plug right in to the bulb socket just make sure to put some plastic epoxy over the nut after all tightend up so the projectors dont ever come loose. also with these projectors theres no having to level the cut off line since they go right into the bulb socket. you will just have to aim your lights after. also get the h1 bulbs if you order them since the projectors wont use ur h4 bulbs. http://www.theretrof...roducts_id=3181 i would also recommend getting some butyl glue to reseal your lense and to make sure you wont have any water leaking in again not really needed but i did it just to be safe and not have to pull them apart again http://www.theretrof...products_id=792
Edited by jdmbb95
Quick bump to the top before I place an order for those morimoto minis
I can use my existing ballasts/high beam relay with the H1 bulbs right?
yes the plug to the ballast is the same
1983 Bmw 320i 5 speed 251000 miles on it
Sundown SA-12d2
Big 3
Optima 75-25
Jensen hlx600 150x4 amp
Hifonics BRZ-1200.1D for sub in a 1.7ft^3 ~33hz ported box
Pioneer USB stereo
Bass knob integrated into old fading switch (Sneaky)
Lowered on H&R sport springs with bilstein sport shocks (2" drop and handles like a dream)
Leave him be. He's just talking shit and laying on his bathroom floor listening to Dashboard Confessional. Let nature take it's course and pump this chick in the butt. Let her know who's boss.
