yo steve what does your voltage drop to when you are beatin i notice you rev it up b4 you play but i know you still c a drop so i was jus wantin to know how low does it go and also do you ever have to charge your batts over night
i also asked the same ? a while back and he said around 14.4 while beating. i'd expect that with three big alternators
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
With the juice that he's got, I highly doubt he's got voltage issues.
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
Guest MegaloManiac
if he said 14.4 then he has a great electrical. if he had said 12.2 then that means his alternators can't keep up and runnin only off batts. but 14.4 is a good number.
i know this guy who has an HO alternator and his voltage stayed at 15 voltages even while beating. he didn't have as much power as meade but 15 is pretty dang good.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest MegaloManiac
yup, mine chills at a steady 14.4
with my 7 amps, 11 batteries and excessive amperage 250 amp alt, i stay steady around 13.9-14.3 :^
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
i asked the question cuz i have dual 220 amp alts and 9 1000 cranking amp batts with 5 runs of 1/0 goin to them and i am running 9000 watts rms and even with me at 3000 rpms i still drain down to low 12's  :R but im not gonna lean on it tho cuz i just got off tha phone with dom and im gonna run 4 300 amp big boys and i wont have any more probs with voltage  :D
  • Who's Online   0 Members, 0 Anonymous, 801 Guests (See full list)
