Help On Finding a 1500 Watt 0.5 Ohm Stable Amp
ThatRockfordFosgateGuy
Wire them to 2 Ohms, get an Rockford bdCP 1500
You'll get a little better sound quality and a lot better efficiency out of it than if you wired your subs to .5 ohms.
*New vehicle and system coming soon.*
your not getting any power out of that amp at 2 ohms. after rise you are screwed. if you wire to 1 ohm on that amp it is the only way to go. then you rise to 2 ish and you get rated.
OP look at sundown DD AQ DC audio SKAR
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Crescendo 2k will do .5 no problem. Just make sure your electrical is up to the task and your gains are set conservatively
great company. i always forget to list them
BMW M340 xDrive
local here has t1500bdcp on stock electrical at .5 and it gets down. Only has big 3 and upgraded main batt and 4 guage wiring beast amp
Don't Let the Pretty Face Fool You, I Roll Like a BOSS :D
2008 Ford Edge SEL
Pioneer Avh-4400 Head Unit
2 Sundown Z V.3 12"s
Mechman 270 Amp Alt Externally Regulated
Sundown Audio Ns-1
Shok Industries 1/0
Xs Power D3400
Xs Power D3100
Lots of Stinger Road Kill Deadner
152.1 DB Legal TL Score (for now)
Build Log
http://www.stevemead...dge-sa8s-build/
Its called Constant Power for a reason
1500watts at 2ohms no problem
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
its called box rise. read up on it big man.
i hope you realize when you wire your 2 D4 12s to 1 ohm you are probably rising to 2-4 ohms and utilizing that constant power you paid for. but when you wire to 2 ohms that BOX RISE puts you 4+ohms most likely and you will see 1k on those subs if your luckily. or you may get lucky and not have a lot of rise but you will still be over 2 ohms. learn a thing or 2 before calling someone out.
BMW M340 xDrive
wiring at .5 is risky on that amp. but some people get away with it. the amp itself just isnt as forgiving as others when wiring to .5,
BMW M340 xDrive
Was judging by the guys name and recommending an Rockford amp for him. He shouldn't lose too terrible amount of power with rise. It's rated for 1,000 at 4 ohms. And Rockford just like all the other companies listed underrate their amps.
I guess if he's worried about the 500 watts effecting how loud it is, he could build the box a little bigger to get more efficiency.
  • Who's Online   0 Members, 0 Anonymous, 1478 Guests (See full list)
