ThatRockfordFosgateGuy Posted July 30, 2012 Report Share Posted July 30, 2012 I Have 2 Rockford Fosgate P3 Subwoofers, and They Are Dual 2 Ohm That Handle 1200 Watts but The Amp I Want Is 1500 Watts, But It Has To Be 0.5 Ohm Stable To Get The Max Power... Some Amp Ideas...? Thanks Link to comment Share on other sites More sharing options...
BobbyG2 Posted July 30, 2012 Report Share Posted July 30, 2012 Wire them to 2 Ohms, get an Rockford bdCP 1500 You'll get a little better sound quality and a lot better efficiency out of it than if you wired your subs to .5 ohms. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 Wire them to 2 Ohms, get an Rockford bdCP 1500 You'll get a little better sound quality and a lot better efficiency out of it than if you wired your subs to .5 ohms. your not getting any power out of that amp at 2 ohms. after rise you are screwed. if you wire to 1 ohm on that amp it is the only way to go. then you rise to 2 ish and you get rated. OP look at sundown DD AQ DC audio SKAR Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
SnowDrifter Posted July 30, 2012 Report Share Posted July 30, 2012 Crescendo 2k will do .5 no problem. Just make sure your electrical is up to the task and your gains are set conservatively ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 Crescendo 2k will do .5 no problem. Just make sure your electrical is up to the task and your gains are set conservatively great company. i always forget to list them Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
BassBarbie Posted July 30, 2012 Report Share Posted July 30, 2012 local here has t1500bdcp on stock electrical at .5 and it gets down. Only has big 3 and upgraded main batt and 4 guage wiring beast amp Don't Let the Pretty Face Fool You, I Roll Like a BOSS 2008 Ford Edge SEL Pioneer Avh-4400 Head Unit 2 Sundown Z V.3 12"s Mechman 270 Amp Alt Externally Regulated Sundown Audio Ns-1 Shok Industries 1/0 Xs Power D3400 Xs Power D3100 Lots of Stinger Road Kill Deadner 152.1 DB Legal TL Score (for now) Build Log http://www.stevemead...dge-sa8s-build/ Link to comment Share on other sites More sharing options...
Avery Howell Posted July 30, 2012 Report Share Posted July 30, 2012 Wire them to 2 Ohms, get an Rockford bdCP 1500 You'll get a little better sound quality and a lot better efficiency out of it than if you wired your subs to .5 ohms. your not getting any power out of that amp at 2 ohms. after rise you are screwed. if you wire to 1 ohm on that amp it is the only way to go. then you rise to 2 ish and you get rated. OP look at sundown DD AQ DC audio SKAR Its called Constant Power for a reason 1500watts at 2ohms no problem 2012 Jeep Wrangler 3.6 W/ 6 Speed Build Log 2011 Ford F-150 SVT Raptor 6.2 Build Log YouTube Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 Wire them to 2 Ohms, get an Rockford bdCP 1500 You'll get a little better sound quality and a lot better efficiency out of it than if you wired your subs to .5 ohms. your not getting any power out of that amp at 2 ohms. after rise you are screwed. if you wire to 1 ohm on that amp it is the only way to go. then you rise to 2 ish and you get rated. OP look at sundown DD AQ DC audio SKAR Its called Constant Power for a reason 1500watts at 2ohms no problem its called box rise. read up on it big man. i hope you realize when you wire your 2 D4 12s to 1 ohm you are probably rising to 2-4 ohms and utilizing that constant power you paid for. but when you wire to 2 ohms that BOX RISE puts you 4+ohms most likely and you will see 1k on those subs if your luckily. or you may get lucky and not have a lot of rise but you will still be over 2 ohms. learn a thing or 2 before calling someone out. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 local here has t1500bdcp on stock electrical at .5 and it gets down. Only has big 3 and upgraded main batt and 4 guage wiring beast amp wiring at .5 is risky on that amp. but some people get away with it. the amp itself just isnt as forgiving as others when wiring to .5, Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
BobbyG2 Posted July 30, 2012 Report Share Posted July 30, 2012 Was judging by the guys name and recommending an Rockford amp for him. He shouldn't lose too terrible amount of power with rise. It's rated for 1,000 at 4 ohms. And Rockford just like all the other companies listed underrate their amps. I guess if he's worried about the 500 watts effecting how loud it is, he could build the box a little bigger to get more efficiency. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
