Glassing in high heat?
As topic suggest what do I or is their anything I need to watch for. The temp at my house has been 100-109 so far. The glass project will be mainly outside no shop or garage to put the car in. The resin is home depo stuff if that helps. Thanks guys for any info or guidance. I'll be making a glass mold for the rear deck.
That!!!
Use less hardener, the heat will make it cure faster. That's the biggest thing you need to know. Second piece of advice is to have a fan either circulating air around, or sucking the fumes out if you're gonna be working in a small area, like the back of a car.
i always error on the side of less. That way if it doesnt harden quick you can slap another layer over it mixed hotter and it will harden that way.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
And that's exactly how I do it lol
Also, don't mix very much resin up at a time. Do it in small cups, so if it does setup too fast, you don't waste that much.
And about half as much hardener, maybe less. It depends on the humidity. If it's low, use VERY little hardener.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
i just did a glass project in 98 degree heat and despite mixing less hardener , i still couldn't work fast enough to work a quart of resin . less hardener and small batches of resin is my $.02 and go go go go go go go once you mix your resin . have it all ready to go before you mix .
  • Who's Online   0 Members, 0 Anonymous, 1316 Guests (See full list)
