So, today i pourchaused a Ground Zero Hydrogen 38X, or its a 15˝ dual 2ohm subwoofer with a FS of 19.3hz...so this project is for the lows...mostly
my space dimension
55cm/21.7inch length or depth-
114cm/44,8inch width--
53cm/20,9inch height---
GZ sub specs in this photo
http://imageshack.us/photo/my-images/444/20120730213239.jpg/
im sorrsy but im trying to type from my em...sort of a tablet computer and is a little difficult
and the frequency i would like to be from 29-32hz...
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
my space dimension
http://imageshack.us...0730213239.jpg/
160L ported 85 cm x 2.5 cm x 38 cm
box tuned to 29hz
Here is a suggestion:
Enclosure Specifications:
Fb = 32 Hz
Vb = 3.38 ft^3
External Height = 13 in
External Width = 44 in
External Depth = 19.75 in
Port Width = 5 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 44 x 19 3/4
Left & Right Sides =
Side 1 = 18 1/4 x 10 3/4
Side 2 = 19 x 10 3/4
Front = 38 x 10 3/4
Back = 44 x 10 3/4
L Port Internal Assembly Parts:
Front to Back = 13 x 10 3/4
Extension = 15 1/4 x 10 3/4
Assembly guide:
after lookn over the specs idd recomend 3.3-3.5net @29-30hz
what car?
how much power?
all stated in my sig...either way my car is a Opel/Vauxhall Corsa C
the amplifier is a DD m1b...aorund 1600wrms at 13,8V
Here are the manufacturer specs:
http://www.ground-ze...s/gzhw-38x.html
They recommend 80 liters net on 1K.
can you get me a box that is tuned a little lower? like 28hz? Edited by gally
Sorry, forgot to convert the values ​​here . The manufacturer is tuned above 40Hz and inappropriate for you
Your small car and thus the max SPL to dodge
whopping gross: 5,728 cu.ft
Port: 2x diameter 3,93700787401575in x length 11,8110236220472in
Box tuned 29hz,
or
slot port : length : 13,7795275590551in x height 1,5748031496063in x depth 13,7795275590551in
box tuning 27,2hz
box tested Citroen Saxo and Toyota Yaris!
simulation and measurement corresponds
good luck gally
Edited by DBL Audio CZ
Box tuned 29hz,
or
box tuning 27,2hz
good luck gally
umm....what?
i dont do this build for SPL....its more like sql it for my own musical taste...
  • Who's Online   0 Members, 0 Anonymous, 3117 Guests (See full list)
