Tarball Posted July 31, 2012 Report Posted July 31, 2012 I'm torn in a decision. Will be running a Soundstream xxx 4000d on 16 charging / 14v batteries. My drivers are a pair of RE MT 15s with dual progressive spiders and dual 1.4 ohm coils and dual tinsel leads. Going into an s10 cut-though. Should I use both 15s @ 1.4 ohms (roughly guesstimating 3300 watts) or a single 15 @ .7 ohms to take the full power from the amp. My concerns are: Overpowering the single (only dual spiders) Underpowering the pair (these subs will need some power to get moving) Would love some opinions from some people that have used the RE MT line. (black magnets not the chrome) CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
RCP Audio Posted July 31, 2012 Report Posted July 31, 2012 Thats alot of power for one sub! If you have the space to do two and it was my build i would go that way, But ive never used the RE subs so I dont know what they can take. hopefully someone chimes in with experience PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
BobbyG2 Posted July 31, 2012 Report Posted July 31, 2012 Maybe sell the amp and get a bigger amp to power the two? *New vehicle and system coming soon.*
jmitch Posted July 31, 2012 Report Posted July 31, 2012 If u have the space for both do both but u may want a bigger amp!! Thats how i would go about it. I know a lil about everything so dont call me Mr. Know it All.
Tarball Posted July 31, 2012 Author Report Posted July 31, 2012 Thanks, I think everyone summed up where I already am in my head. Gonna build with two and go with bigger amp after break in . Would be nasty on a SKAR 4500.1 CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
