Trying to decide if i should just have a trigger job done on my ar 15 or if a drop in trigger would be a better option
Im looking at Timney and JP...
Anyone with experience with either input is appreciated
Team MaxRetribution
Si Vis Pacem Parabellum
geisselle automatics.
do it yourself its not hard at all. you'll need a punch and thats about it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The other thing that is plaguing me is that in my owner's manual for my Ar-15 it says that it came with an adjustable trigger
Team MaxRetribution
did it come with different springs? If the answer is no then its not adjustable.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
No there are not any other springs with it... Apparently the trigger has 2 notches in it that if you switch spring position it will lighten trigger??
** Just going by what is in the print
Team MaxRetribution
You have to ask a few questions to find out what your looking to do why/what do you want to change:
** does the trigger have a gritty feeling to it?
** is teh pull weight to much?
** is there to much take up or over travel?
9/10 most people are happy with a well worn trigger. If your gun has under 1000 rounds yo may benefit from simply putting lapping compund on the hammer and sear and speeding up the process of normal wear.
I gotta make my kid lunch. I'll post up later about a few things
Rolex you sicken me.
Just let me finish my pie
~ Juice
I mean the trigger is bearable but it is rough and has quite a bit of slack in it before you feel it start to engage....
Im not looking to run a hair trigger i would just like to run a nice clean 4-4.5lb trigger that is smooth and breaks cleanly...
Team MaxRetribution
  • Who's Online   1 Member, 0 Anonymous, 511 Guests (See full list)
