Ok to build wall on folded seats and with headliner in?
Y not just 1 18 and your 2kw below the window line should beable to get 150 with that
with 1 18, on 1600 (not including voltage drop which is reallly bad right now. i can only hit 141.9...on music
then beef up your elec before you even consider adding more power, your getting bad voltage drop on 1600, what do you think will happen with 5k
Used to have a loud truck
if you do decide to do a cpillar wall you should have around 17 cubic foot, you may have more or less if the grand cherokee is bigger or smaller than a regular cherokee
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
against the door meaning inch. half inch even. ill post a video in like an hour. . . box specs are 6 net cubes. tuned to 32hz. double baffle. sub up port back.and its at the window line. again ill post a video about an hour and about the voltage drop. why the money im getting a HO alt and some batterys so thatll clear that up
17cubes of what? space from the rear seats?
from the rear seats to about 2 or 3 inches before the hatch
  • Who's Online   0 Members, 0 Anonymous, 1461 Guests (See full list)
