Bdurb Posted August 3, 2012 Report Share Posted August 3, 2012 So i am walling my wagon, here is what i have to play with, looking to get around 7 to 8 cubic feet heres what i have to play with Doing two Obsidian 15s Height - 30 inches Width- 42 Inches Depth- 20 Inches i want to control volume by depth, as this is a wall. Few questions Where should the port be? Top, side, or between the two subs, I want it tuned around 28 to 32hz just basically need some port measurements and would love to have a wide port to crawl in......... just because. any help is greatly appreciated as this is my first wall. My old Build Log! http://www.stevemead...der-in-a-jetta/ Two Obsidian 15s V2 Two Audiopipe Apsm 1500s Fourth Order Wall TEAM CLEARLY LOUDER TEAM OBSIDIAN AUDIO Link to comment Share on other sites More sharing options...
KangHzAudio Posted August 3, 2012 Report Share Posted August 3, 2012 With the Formula LxWxH Divided by 1728 We get you are at 14.58 cuft Now you want a port you can climb into,that will be a little tricky.. Most the ones with Giant ports a tuned pretty high. If we was to make the port 30inches and 15 as the width, you would need to have the length be about 80 inches.. I will mess around and see what i can do Link to comment Share on other sites More sharing options...
KangHzAudio Posted August 3, 2012 Report Share Posted August 3, 2012 But then you have to factor in Displacement of the subwoofer and subtract that and then also the MDF... They recommend you use a ported box up to 3.75cuft... But from what I can gather you won't be able to climb in your port unless you are 10inches tall lol Link to comment Share on other sites More sharing options...
john253a Posted August 3, 2012 Report Share Posted August 3, 2012 Idd do port top or between subs depending on rear seat height, Are you going to build in car or outside and make trim pannels for the sides You also named to give a bit more info, Amp power and seat heights Link to comment Share on other sites More sharing options...
Bdurb Posted August 4, 2012 Author Report Share Posted August 4, 2012 it looks like ill have to do 6 inches wide port, but i am building outside of car and then making trim panels, and seats can be folded down, so i was just wondering what the real differnce with the location of the port or if there is any, and as far as amp, i havent decided. Not going to give more than 1000w to each though. My old Build Log! http://www.stevemead...der-in-a-jetta/ Two Obsidian 15s V2 Two Audiopipe Apsm 1500s Fourth Order Wall TEAM CLEARLY LOUDER TEAM OBSIDIAN AUDIO Link to comment Share on other sites More sharing options...
Bdurb Posted August 4, 2012 Author Report Share Posted August 4, 2012 so here is what the re box calc came up with, length is 43 inches 30 inches high 18 inches deep 3 inch wide port, 28.5 across, 41.5 total port length tuned at 28hz My old Build Log! http://www.stevemead...der-in-a-jetta/ Two Obsidian 15s V2 Two Audiopipe Apsm 1500s Fourth Order Wall TEAM CLEARLY LOUDER TEAM OBSIDIAN AUDIO Link to comment Share on other sites More sharing options...
john253a Posted August 4, 2012 Report Share Posted August 4, 2012 without knowing the height of rear seat (idd assume 16-20h) your port may be restricted a bit at the bottom you may be after something similar to this Link to comment Share on other sites More sharing options...
Joe X Posted August 4, 2012 Report Share Posted August 4, 2012 If you are folding that seat to place the box then probably this other suggestion will suffice: Enclosure Specifications: Fb = 32 Hz Vb = 7.47 ft^3 External Height = 30 in External Width = 42 in External Depth = 18 in Port Width = 32 in Port Height = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 42 x 30 Left & Right Sides = 15 3/4 x 28 1/2 Top & Bottom = 42 x 15 3/4 L Port Internal Assembly Parts: Front to Back = 12 x 33 1/2 Extension = 13 x 33 1/2 Port Left Side Assembly: 12 x 3 3/4 17 1/2 x 3 3/4 Port Right Side Assembly: 12 x 3 3/4 17 1/2 x 3 3/4 Let me know any questions. Link to comment Share on other sites More sharing options...
Bdurb Posted August 7, 2012 Author Report Share Posted August 7, 2012 thank you so much that looks wonderful. My old Build Log! http://www.stevemead...der-in-a-jetta/ Two Obsidian 15s V2 Two Audiopipe Apsm 1500s Fourth Order Wall TEAM CLEARLY LOUDER TEAM OBSIDIAN AUDIO Link to comment Share on other sites More sharing options...
Bdurb Posted August 7, 2012 Author Report Share Posted August 7, 2012 would it be possible for you to post the cutlist on the first design? My old Build Log! http://www.stevemead...der-in-a-jetta/ Two Obsidian 15s V2 Two Audiopipe Apsm 1500s Fourth Order Wall TEAM CLEARLY LOUDER TEAM OBSIDIAN AUDIO Link to comment Share on other sites More sharing options...
