XS Power
so this would be good for a daily driver and local new orleans area crank it ups and scraping the coast type stuffing. cause right now it his only ride, saving up to put down on a vette. then it will just be car show type stuff
2006 Suzuki Hayabusa GSX1300R Limited Edition
2006 Dodge Charger SXT
Kenwood Excelon KDC - X692
Factory Boston Acustics System upgrade (7 speaker system)
2010 Chevy Tahoe LS
Pioneer AVIC - Z130
Audiopipe AP-2004
Audiopipe AP-15001D
(2 pair) Boston Acoustics PRO60SE 6.5 - changed to Polk Audio MM6501
(2) Planet Audio BB215D - changed to Lanzar Opit 1533d for now FREEBIES
Sorry I disagree with that vid
I have tested my car with just backk chassie ground the ground from batt to batt and tested again with batt and chassie ground
I gained .3 volts with the batt to batt ground vs just chassie ground and gained .1. More volt with batt and chassie ground together
Needless to say all my systems have front to back and chassie grounds .4 volts is alot
Wait I must be wrong there iis a youtube vid showing so I no longer have to test things for myself ill just do what youtube says and watch all the exo vids to learn lol
Not to thread jack, but I previously had my system ground with a - wire front to back with no chassis ground. had just a tiny drop at idle. none while revving. Redid my wiring and now I just have my back battery and amp grounded to chassis. At idle I drop down to 12v at full tilt. drops to 13 while driving. Now I am going to have to rewire again lol. And I do have the paint sanded on a ground straight to the frame. I'm only running under 4k watts and i have a 270 amp alt, d3400, and shuriken bt80. So there shouldn't be any voltage drop at all. I agree that a wire front to back will do better in some setups.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
thanks guy for all this info, much needed
2010 Chevy Tahoe LS
Pioneer AVIC - Z130
Audiopipe AP-2004
Audiopipe AP-15001D
Every car is different. You have to keep that in mind.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
No way!!! really?
guess my sarcasim was over looked
Its amazing how many people swore up and down that you always needed equal runs of the same gauge cables from the front to rear, until this video came out. I wonder how much bad information about running cables was given out before this video. And where did the whole run cables instead of chassis ground even start?
this is still true for high power systems. they did state its only good for a bit of watts. if youre going to run 30,000 then you will need shit load of wire to run power and ground
I would run at least 1 dedicated ground cable if you're over 2KW. The chassis/motor/alt/battery ground system isnt always perfect, even with a "big 3."
Hammerdown... 1%
Yes do a ground run front to back like the power.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
