Digital Design 1508
Humbol
so i have a digital design 1508 in the stock enclosure running off an alpine mrp m-500 and i was wondering when i played no hands by waka flocka the sub made a popping noise? but when i turn the volume down the popping noise seems to dissapear? what could that popping sound mean?
89 Toyota P/U Single Cab
HU - Kenwood x-396
Front Stage - Kenwood KFC-1094PS
Rear Stage - Kenwood KFC - 6984PS
Sub - Alpine SWR 823D
Amp - Alpine MRP M500
Could be loose dustcap, tinsel slap, overdriving the signal. Check over sub, try turning gain down see if it helps.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Check your gains, bass boost and the input voltage to the amp besides checking it physically for damage.
should i tune the amp with the sub level at 0?
HU - Kenwood x-396
only if you're going to leave it at 0 and never touch it again.
popping could be the voice coil tapping the back plate (bottoming out)
Hammerdown... 1%
but sometime when listening to music i usually go up to +7 but for some songs if i go to +9 and up thats when the popping noise starts
HU - Kenwood x-396
you're bottoming it out. does it make that noise on the low part of no hands?
yezzier just those low notes
HU - Kenwood x-396
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
