cjvue Posted August 11, 2012 Report Posted August 11, 2012 This would probably disqualify you but, You could just compensate with battery reserve (like 10-15 big batts), fuse between the front battery and the rear bank, then don't fuse between the rear bank and the amp. The fuse will go fairly quick but the battery bank in back will let you play longer without the alt helping. Problem is, it's not safe, you would really have to watch voltage, and they may frown on the no fuse between 10-15 batteries and the amp. I am not familiar with the meca rules so like i said, you may get dq'ed for something like that. Class 4 and below require fuse(s).... 18" or shorter between amp and batt My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
alaskanzx5 Posted August 11, 2012 Report Posted August 11, 2012 do they have a limit on batteries though? keeping better voltage at the smaller amperage the fuse can handle might still buy you a few second. besides that the only thing i can think of is starting at a lower volume and crank it up right as the timer starts. or as they already said roll into it and look into different brand fuses. check out the other competitors in your class that dont have that same issue and see what they are doing for fusing might give you some ideas t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
pa-pa-platypus Posted August 11, 2012 Report Posted August 11, 2012 quick question OP...you dont happen to compete in the effingham illinois shows do you? This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
wilcox_81 Posted August 15, 2012 Author Report Posted August 15, 2012 quick question OP...you dont happen to compete in the effingham illinois shows do you? Yes i do compete in effingham i am going to try running two fuses and see if i helps. When i run i am running at .25ohms im i s3 class im running two 15" dc audio,s with a 3.5 dc audio amp im going to try to lower my volume and role to gain knob up and see what happens hopping to hold longer and get a better reading
wilcox_81 Posted August 15, 2012 Author Report Posted August 15, 2012 30 seconds run Ive used a 150a on my bc5500 at. 5, held just fine i am running my 3.5k at .25 ohm when i run so it is pulling pretty hard when i start i have dual 1 ohm subs
stevew007 Posted August 17, 2012 Report Posted August 17, 2012 so i have no idea about the rules BUT is this why i have seen big like bussbars full of 40amp glass fuse's? does that help with the current?
wilcox_81 Posted August 24, 2012 Author Report Posted August 24, 2012 So people do that because I am guess you can bet alot off different sizes in those compared to anl fuses and alot smaller sizes also
