wilcox_81 Posted August 8, 2012 Report Posted August 8, 2012 I run in meca in s3 class i have two 15" lvl 4 dc audio with a 3.5k on them. i have hit 147 sealed with the 3.5k but have a problem doing when i change my fusing when i am run meca. When i am runing meca i have to use a 150 amp fuse its an anl fuse if you were wondering. But when i do use it, it only last a second or two at the most and dont know why. My class i run is s3 i have two 15" lvl 4 dc audio m2 with all lvl 5 parts on them. Direct leads on the subs and copper coils. To stay in my class with the 3.5k i have to run a 150 amp fusing to stay in my class. If i put a bigger fuse in i will be pushing in to the next class. The problem i am having is when i go up to run the fuse only last a second or two at the most. What i do when i run is i turn my head unit at the volume i am going to staying at the then i turn up my gain knob. But before i can realy turn up the gain the fuse blows and it has done that every time i go up to run and not realy sure why. But know i am going to getting ride of my 3.5k for an american bass 500.1 or a dc audio 5k but sure which one yet. I am guessing that i will have the same problem i am with my 3.5k because the 3.5k takes a 300 amp fuse for total power. and the other amps take like 400 amps or more to run them at full power. So if you have any info i would realy appreciate it thanks.
Miguels Posted August 8, 2012 Report Posted August 8, 2012 you are running too small of a fuse.. you can always turn down your gains my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
pa-pa-platypus Posted August 8, 2012 Report Posted August 8, 2012 you gotta cook it a lil longer This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Guest Posted August 8, 2012 Report Posted August 8, 2012 pulling upwards of 350 amps through a 150 amp fuse. you cant see why?
Miguels Posted August 8, 2012 Report Posted August 8, 2012 pulling upwards of 350 amps through a 150 amp fuse. you cant see why? he wants to upgrade to a 5k.. it will only make it worse.. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
pa-pa-platypus Posted August 8, 2012 Report Posted August 8, 2012 you gotta roll into it... This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
fecupe2001 Posted August 8, 2012 Report Posted August 8, 2012 gotta love meca I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
cjvue Posted August 9, 2012 Report Posted August 9, 2012 I use 160amp (2 - 80 amp) fusing on my ab500.1 @ 0.5 ohm before without issues.... I roll my volume though.... I'm also in S3... My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
kr15 Posted August 9, 2012 Report Posted August 9, 2012 I burp my dd m3 at .5 on 60a and get a fine burp...im guessing your clipping quite a bit or having nasty voltage drop due to inadequate electrical Team Flex Issues Low tuning > God 2011 CALI AS1 STATE CHAMP
