DD-1 and a couple RF2500.1
Since the 2500's have the distortion detector built into it i have always used it to set the amps up. Hover now that I have my DD-1 the amps show distortion before the DD-1 does. Should i be going off the amp's or the DD-1's.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
the 2500 does not have a distortion detector in it LOL sorry bro.
Follow my Tweet (Twitter)
if you are talking about the "needles" turning red, that is not "distortion" that is just it reading output and not even maximum output. They just go into red when you start pushing a lot of power out. Totally unrelated to clipping or distortion.
From the man HIMSELF ^ glad i have a DD1 =]
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Thanks for clearing that up. I will be regaining my amps then..
