OK!
I just got this weird arse problem. Whenever I have my stereo receiver (Sherwood AD255R) set to play on both channels on the fader, my sub isn't as powerful, whenever I set the fader to full left or full right, the sub has more power.
The sub is a KLH Audio E-12DB. Hooked up like this....
And for those who can't clearly see the writing on the sub amp, the top one is the input from the receiver, and the bottom row goes to my mids/highs.
Um I would just say since you shift it all the way to the left it cuts off the power to the right speakers there fore leaving more power for the sub to take from the amp Im not sure though
assuming the sub has two inputs (one red one white) the fader controls which one the sub gets the power from. now if u have it set in the middle the sub wont get the same amount of power from both sides and the amp will compensate to creat a "natural" sound.
so im pretty sure if u pick one of them (red or white) put a splitter on it and put it into both inputs, itll get the same amount of voltage from both inputs constantly thereby making it the same "loudness" as if it was full left or right
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Oh... Doh! :blink:
Meh. I wish my receiver had an actual sub output... :mad:
The amp itself is crap anyways too. :lol:
Thanks.
Oh... Doh! :blink:
Thanks.
lol thats ur problem
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Yeah... It's currently hooked up with speaker wire *see first post*.
It works but if I listen carefully, the LPF on the sub amp doesn't work the way it should cause I can hear the vocals sneak in distorted from the sub... AGH!!!!!!!!!!!!!!!!!!!!!!!!!!!
I beleive thats the same home theater sub that i have, 120 watt 10"? I havent had any problems with the LPF on mine, but then again i have it connected from the sub out on my sony receiver.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
Mine's a 12".
Bah, I'm gonna try a diff plate amp once I have the money, see how it goes. :)
ditto
My home receiver had 4 towers running off it (eight 15s) using channels A and B and you could easily hear the tweets starving for power. The stereo was actully louder/cleaner with only 2 speakers running at a time til I got a older receiver too power the other two. Then sold to a friend when I was unemployed :( four 15s ftl now..
  • Who's Online   0 Members, 0 Anonymous, 927 Guests (See full list)
