Your amp has no part in this problem I'm sure. Your connection to your ring terminal seems to be the issue. I got my little torch from Harbor Freight for like $10? Butane was only a couple. You need to get those connections fully wicked(flux through to the core of the wire). Once you have a solid connection on your terminal, see what happens. If you still have a problem, that place where the wire is cut is a concern for sure. Does that keep happening to ALL the wires you're adding, the cut?
  • Who's Online   1 Member, 0 Anonymous, 898 Guests (See full list)
