CleanSierra Posted August 10, 2012 Report Posted August 10, 2012 Here's a couple of mine, not sure if they show the sane area you need: Quote Im not the one you want to try to troll. Just a fyi for you.
Guest Posted August 11, 2012 Report Posted August 11, 2012 (edited) . Edited January 13, 2024 by Dtowndubzz Quote
christamez80 Posted August 11, 2012 Author Report Posted August 11, 2012 I just have a cheap soldering iron, no torch. The crimper I borrowed from a local shop but it's the type u have to hit the top with a hammer. Yeah and I have one wire goin to alternator and one goin to fuse goin to amp in the bak. The amp is a cadence zrs100.4 that I have on mids and highs. Quote
CleanSierra Posted August 11, 2012 Report Posted August 11, 2012 Your amp has no part in this problem I'm sure. Your connection to your ring terminal seems to be the issue. I got my little torch from Harbor Freight for like $10? Butane was only a couple. You need to get those connections fully wicked(flux through to the core of the wire). Once you have a solid connection on your terminal, see what happens. If you still have a problem, that place where the wire is cut is a concern for sure. Does that keep happening to ALL the wires you're adding, the cut? Quote Im not the one you want to try to troll. Just a fyi for you.
Lbox88 Posted August 11, 2012 Report Posted August 11, 2012 Go to Lowes, you can get a propane torch and tip for $13, also grab a can of the flux(can't remember name lol) and a spool of rosin core solder. NOT acid core. Quote UBL | Build Log
christamez80 Posted August 11, 2012 Author Report Posted August 11, 2012 Yes every wire I put on does this but it just recently started that's wut concerns me. I had 2-15's L7's in there with 2 planet audio B2B2400.1 and didn't have this issue at all and now that I took it out its doing this. Quote
