Need help with bracing for 6 18's box!!
2 to the side should suffice honestly..just space them evenly and flex shouldnt be a giant issue..also one you may want to think about is back to front.. wheres the plan to mount the amp?
going to mount an amp rack on the front of the box behind the front seats. And it will be tough to brace from front to back since it will be about 65" deep.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
then i would for sure double up on the back and the front pieces that dont have bracing on them..as they would be potential weak points
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
You could always another another baffle or 2...
I would, but height is also an issue. The way the headliner comes down on the sides, there won't be much clearance. I will double up on the front and back pieces. and how do I figure in bracing displacement inside the port?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
Any help on how to calculate port bracing displacement? How would a threaded rod effect tuning?
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
very little if at all...it might lower it .3 hz or some small amount..i wouldnt worry about it
power: dd m4
that box is pretty slick with the angle cut bracing.
this is mine.
inch all thread. sides and top and bottom are well braced or will be. front to back was my main focus.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Ok, thanks a lot. You've been a big help.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
this is mine.
http://www.stevemead...dian-audio-18s/
check this build out....how he used the 2x4's
Will check those pics at 5 when I get off work. Damn work has all the pics blocked.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
  • Who's Online   0 Members, 0 Anonymous, 1079 Guests (See full list)
