box help
I've tried and tried to download Torres and for some reason I can't. So, since I can't download it would someone help me design a box for a skar ivx 15? If anyone is willing to help, here is what I'm working with.
Equipment:
Sub: Skar ivx 15d2
Amp: hifonics Zeus 500.2
Vehicle: 1991 Lincoln towncar
Trunk is pretty damn big so not really limited too much for a single 15, but I'll go get exact measurements real quick.
Goal: as loud as it can get for a daily box!
I listen to mostly rap.
I'm going to run it bridged at 4ohms, so it will be over-powered but it will be tuned with a dd1.
The specs of the sub say 3.5ft^3 @35hz
Edit: measurements of trunk is 26"H X 29"D X 42"W. That is usable space measurements. Actual trunk measurements are 27"H X 60"D X 55"W.
The trunk of a towncar is designed weird which is why usable measurements are so different than the actual size of the trunk.
Edited by qcbangin
Here is a suggestion for your IVX15:
Enclosure Specifications:
Fb = 34 Hz
Vb = 3.5 ft^3
External Height = 16 in
External Width = 37 in
External Depth = 17 in
Port Width = 3 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 32 7/8 x 14 1/2
Back = 37 x 14 1/2
Left & Right Sides:
Side 1 = 15 1/2 x 14 1/2
Side 2 = 16 1/4 x 14 1/2
Top & Bottom = 37 x 17
L Port Internal Assembly Parts:
Front to Back = 12 1/8 x 14 1/2
Extension = 8 x 14 1/2
Let me know any questions.
Edited by Joe X
Thanks alot for the help. I appreciate it. Now I just need the sub/amp and wood! I'll let you know if I have any questions or run into any problems. Is the vb after displacements?
Fb = 34 Hz
Vb = 3.5 ft^3
Cut Sheet List:
Back = 37 x 14 1/2
Left & Right Sides:
Edited by qcbangin
If you were to not include the 45's at all what needs to change on your measurements to compensate?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Got to work on the box today. Don't seem to be having any problems so far. Its looking great. Thanks alot, I really appreciate it.
I do have question, tho. Does it matter where I put the sub at on the baffle? Should I put closer to the port, or further from the port?
It is good that there are people like Joe on here. People like him who are willing to help people without asking for anything in return. I asked for help, and he was quick to help. Had me a design in less than an hour after I posted. Thanks again, Joe. I appreciate it. When I figure out how to upload pics, I'll post some pics.
Edit:one more question Joe. On the L port, where the 2 pieces meet, is it ok that its a corner and not rounded? Or does it need to be rounded? It just seems a lil close to the 45 in the port corner.
Edited by qcbangin
  • Who's Online   0 Members, 0 Anonymous, 1574 Guests (See full list)
