PPI
Art Series
300.2
Purchased from a local dealer 8/11/12 from a clean out sale fir $60. This amp was used and is at least 15 years old.
Powered up with no problem. Functioned fine though output not as rated.
75x2 at 4 ohms or 300x1 bridged at 4 ohms.
Here's the real numbers:
Left channel 69 watts:
Right channel 64 watts:
Bridged 278 watts:
Rolex you sicken me.
Just let me finish my pie
~ Juice
Kinda surprising since most of the high end old school amps seemed underrated to me. Like the lanzar optidrive 50c and optidrive 500 if I remember correctly.
Pioneer deh-8300UB
6- Image Dynamics CSX6.5v2
4-Image Dynamics XS-28 tweeters
4-Sundown Audio sa8v2's
1-Sundown Audio SAX-200.4
1-Sundown Audio SAX-1200d
1-Mechman 270a alternator
1-XS Power D3400 under hood
Second Skin Damplifier Pro Deadener
Kicker & Knukoncept 1/0 wiring
Big 3 upgrade
On the PPI I wasn't surprised to see it just a hair under the mark. I was surprised though at the fact that the channels were .7 volts apart.
~ Juice
Made in the USA right?
Pioneer deh-8300UB
Big 3 upgrade
Yup, took hi res pics with my nikon for the amp guts section. I took a good one of the made in the USA logo and huge flag on the board
~ Juice
After 15 years used the caps inside can get weak and go bad they are basicaly 15 year old batts. For how clean the ppi is and it to be close to rated still good to me ill buy it off you for 60 bucks if you don't want it
Cap replacement.
Also, it is also an unregulated power supply.
You give it 14.5v during the test?
Negative,
It's a regulated power supply!
I never knew caps could gradually go bad I thought they were either functional or dead. Thanks for that info.
~ Juice
I own 3 of them..
I have done clamp tests at low and high voltage.. There is a difference.
Thats all, i know what the manual says. Try it if ya got time.
I will, I'll make time. (ya right, who has all the time to do everything they want)
Was it a noticable gain with voltage incerease? On my bench it was getting 13.8 Volts with no load. I would think it would gain some more power under load as well though the current draw would proportional to teh load.
Either way for 15 years and $60 who's going to argue? I have another 300 and a 1200 that I may swap into teh car just to see what the PPi setup can do.
75x4 and 1200x1, might be a good combo
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 1854 Guests (See full list)
