I forgot to mention that the other sub is working fine and never had a problem like this.
It can pivot on the metal thing circled in white.
The terminals circled in blue connect to other terminals on the opposite side of the sub.
The terminals circled in red ( the ones Im having the problem with, specifically the negative terminal) are connected to the sub box terminals that connect to the amp.
tinsel leads look dark what is the gain on the rockford
check ground on the amp make sure its secure and there is no paint where it is bolted down
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
Those connections tend to rock a bit side to side. Finding one that will fit tight and not move around is hard to come by. If you have a multi meter (digital or analog) check the resistance on the tinsel leads (the wires that attach to the rear of the terminals that go to the inner area of the sub where the spider assembly is). Check and tell us the resistance it reads. Then try to do that but with the multi meter connected to the spade terminal on the speaker and wiggle the tinsel leads around one at a time. If you get a reading that changes then you have a loose tinsel connection and may just need to solder the wire back onto the terminal to fix it.
