I have a 200 amp Ohio Generator alt and wish to fuse the 0 gauge goin to the battery what size fuse would I use? 200?
I also added 4 gauge from alt to fuse box under hood ..is this ok? and i would like to fuse that do if its ok and what size would I use for that?
Edited by fosgatefan821
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
afternoon bump
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
Your fuse should always be greater than your max amperage. Our Mechman alternators are underrated, so if you had one of our 270amp alternators you would need close to a 300 amp fuse. A little cushion goes a long way in preserving your electrical system and stereo components / accessories. I hope this helps.
Michael
[email protected]
yes that helps alot..thanks so i have a 200 so i should get bigger than 200amp fuse if possible.. and i wish to fuse the 4 gauge i have from alt to cars fuse box under hood is that safe and what fuse would i use for that over 200 as well?
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
i always read fuse for what your wire is rated.
so 1/0 should be fused for 300 amps.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
thanks ... added 4 gauge from alt to the factory fuse box under hood ..is this ok? and i would like to fuse that to if its ok and what size would I use for that?
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
The factory wires in most cases have fuseable links added in at the factory. I am not certain if this is used anymore on newer cars, but older cars from 90's, and early 2000's had them I know.
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
gotcha ..i gotta 02 monte carlo ss im goin to fuse it when i figure what size fuse to use
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
I´m not the biggest expert about electricals, is that fuse really necessary? i used an ANL 250A fuse for the line in my suzuki swift wich had a 140A alternator, i ditched that thing and didn´t have any problems at all, that´s why my explorer doesn´t have that fuse either, should i install it? my positive runs from main batt to the batteries on the back does have fuses
If the fuse ever did blow it would only stop the alternator from charging the battery through the added wire. (Like if you did the big 3, the blown fuse would stop the alternator from charging though your big 3 power wire.)
The wire would still be live on both sides though (alternator charging one side, battery hooked up to the other side) and the alternator would still be charging the battery through the stock power wire, unless you've removed it.
So there's not a WHOLE lot that a fuse can do in that situation. It makes some people sleep easier at night though
  • Who's Online   0 Members, 0 Anonymous, 2575 Guests (See full list)
