XS Power
If you can id recommend buss bars. They handle more current than power wire between each battery could and depending on how they are made for you they are cleaner looking and easier to use. There are buss bars out where you just strip back the wire, insert it into the buss bar and tighten down an allen head screw on the wire. Just like what amplifiers have for power input connections. Then if you really want to get it looking cool you can have them engrave the buss bar with something to make it stand out. My batteries perform great off having the tsunami 1/0 wire connecting them all together however if it wasnt for how the batteries arent 100% level with one another id totally get buss bars to make it cleaner back there.
I believe you are thinking of set screws.
I'm gonna hate
Yes thank you. I was trying to think of the correct name but was coming up blank. lol. I prefer those over ones that require ring terminals on the wire as you can make them neater and fit a lot more on the buss bar than to cram a ton of ring terminals together in one location.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
even without the load adjusters, i would be able to carry the weight, it would just sag a bit. The load adjusters keep the truck level after about 1500 lbs in the bed
yea they can take the load stock..only reason i mentioned the suspension was because i just had it happen after installing a 5" lift on a ranger to put 35's on it and once we put the batteries back in they rubbed ...thats a lot of tire on a ranger i know but even with the same weight they came close to rubbing with 31's on there had to invest in some air shocks(not my choice my friends) after the 35's
1 Fi Sp4 18
Crescendo 2k
selenium mids
audioque supertweets
Hifonics for mids and and highs
1/0 power and grounds
---> on the way singer alt and possibly another
2k depending how sub likes 1 2k
if you find somewhere for some bussbars pm me ive been looking but there's a good wait time at a lot of places
1 Fi Sp4 18
Crescendo 2k
selenium mids
Have you checked with toolmaker on here? He makes great buss bars but im not sure if he has a backorder or what for getting them out the door.
