2012 Challenger Trunk Build, 2 RE SEx 15's, HiFonics GLX 1400.1D
what small indentations are you talking about that wouldn't let you go ported? i dont quite understand
pulled up a stock picture of the trunk to show you, I could do ported but I still would like to have trunk space. if I went anything wider than 33" I would have had to sit it on top of those indentions, and lower the height as it's only 17" high at that point, or scoot it forward and front fire. I value my trunk space. Those indentions on the bottom sides will not move, there is metal underneath from wheel well.
2012 TORed Challenger
4 Alpine Type-R 10
1 Brutus 2400.1
20' Knu 1/0 OFC
1 XS Power D1200
Looks nice and solid, sick car too.
Whats the volume of the chambers? They do look a little large.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
oh i gotcha. i would've just said fuck it and fired forward lol. but to each his own.
After displacement, about 1.95 per chamber. Optimal sealed for the RE SEx 15 would be 2cf
Normally, I would have as well. But for once i'm trying to go big BUT keep my trunk space at the same time. Killed me in my mustang, I had probably 3 cf left in trunk after box :(
4 Alpine Type-R 10
1 Brutus 2400.1
20' Knu 1/0 OFC
1 XS Power D1200
I'm not sure if it woul've gained you much space, but you could've had small indentions on the bottom sides of the box. I know you already built it, but I was just throwing that out there.
I really considered it, but I really was not feeling like dealing with the cf adjustments and all of that. I feel ya though, thought about it too!
4 Alpine Type-R 10
1 Brutus 2400.1
20' Knu 1/0 OFC
1 XS Power D1200
Hmm will watch this build :rolleyes:
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
Looking nice, but even though your battery is in the trunk of the car and makes wiring a lot easier, you still might want to consider running a new charge line from the alternator to the back battery. The factory charge line is probably, at the most, 4 gauge wire. Good for running stock, but now you have an amp drawing power off that battery and will most likely cause you to have voltage drop. Just a heads up.
formerly known as Blue86f150
this sux camel dicks
Or worse. Never want to toast wire.
I'm gonna hate
