Need box help HDC3 12
kinda depends on how much power you're giving it.
It will be running at 1ohm off of a Hifonics hfi2000d, so it will probably be running 1700-1800 maybe less since I'm pretty positive that amp doesn't do rated.
I'd do about 2.5 cubes maybe even bigger. tune higher, like 36+ plenty of port
torres calculator can be downloaded on a mac, it just takes some extra steps that are all explained on the first page.
Edited by 412 CVX
More box builds
I'm with captain stupid.
Ahh thank you, I'll work on doing that today
Can you go a little deeper or wider, guessing this is a trunk car.
I could go 6" wider but I would like to keep my current dimensions instead of having to buy all new wood
Here is a suggestion, took the 6" wide and 1" deep to reach the spec, hope you can fit that:
Enclosure Specifications:
Fb = 36 Hz
Vb = 2.5 ft^3
External Height = 13.5 in
External Width = 36 in
External Depth = 17 in
Port Width = 3 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 36 x 13 1/2
Left & Right Sides = 14 3/4 x 12
Top & Bottom = 36 x 14 3/4
L Port Internal Assembly Parts:
Front to Back = 11 1/4 x 12
Extension = 10 13/16 x 12
Assembly guide (generic dimensions):
Let me know any questions.
Fb = 36 Hz
Vb = 2.5 ft^3
Cut Sheet List:
Thank you very much Joe!
  • Who's Online   1 Member, 0 Anonymous, 1101 Guests (See full list)
