BenzBass Posted August 20, 2012 Author Report Posted August 20, 2012 kinda depends on how much power you're giving it. It will be running at 1ohm off of a Hifonics hfi2000d, so it will probably be running 1700-1800 maybe less since I'm pretty positive that amp doesn't do rated. Quote
412 CVX Posted August 20, 2012 Report Posted August 20, 2012 (edited) I'd do about 2.5 cubes maybe even bigger. tune higher, like 36+ plenty of port torres calculator can be downloaded on a mac, it just takes some extra steps that are all explained on the first page. Edited August 20, 2012 by 412 CVX Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
BenzBass Posted August 20, 2012 Author Report Posted August 20, 2012 I'd do about 2.5 cubes maybe even bigger. tune higher, like 36+ plenty of port torres calculator can be downloaded on a mac, it just takes some extra steps that are all explained on the first page. Ahh thank you, I'll work on doing that today Quote
BenzBass Posted August 20, 2012 Author Report Posted August 20, 2012 After trying to install Torres for a good while, I've had no luck. Anyone feeling nice today and want to design a box for me? Quote
Joe X Posted August 20, 2012 Report Posted August 20, 2012 Can you go a little deeper or wider, guessing this is a trunk car. I could go 6" wider but I would like to keep my current dimensions instead of having to buy all new wood Here is a suggestion, took the 6" wide and 1" deep to reach the spec, hope you can fit that: Enclosure Specifications: Fb = 36 Hz Vb = 2.5 ft^3 External Height = 13.5 in External Width = 36 in External Depth = 17 in Port Width = 3 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 36 x 13 1/2 Left & Right Sides = 14 3/4 x 12 Top & Bottom = 36 x 14 3/4 L Port Internal Assembly Parts: Front to Back = 11 1/4 x 12 Extension = 10 13/16 x 12 Assembly guide (generic dimensions): Let me know any questions. Quote
Guest Posted August 20, 2012 Report Posted August 20, 2012 (edited) how did i even know you were going to pop into this thread. i can predict it almost every single time. Edited August 20, 2012 by Kranny Quote
BenzBass Posted August 20, 2012 Author Report Posted August 20, 2012 Can you go a little deeper or wider, guessing this is a trunk car. I could go 6" wider but I would like to keep my current dimensions instead of having to buy all new wood Here is a suggestion, took the 6" wide and 1" deep to reach the spec, hope you can fit that: Enclosure Specifications: Fb = 36 Hz Vb = 2.5 ft^3 External Height = 13.5 in External Width = 36 in External Depth = 17 in Port Width = 3 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 36 x 13 1/2 Left & Right Sides = 14 3/4 x 12 Top & Bottom = 36 x 14 3/4 L Port Internal Assembly Parts: Front to Back = 11 1/4 x 12 Extension = 10 13/16 x 12 Assembly guide (generic dimensions): Let me know any questions. Thank you very much Joe! Quote
