I have a opti6k and with a d6500 under the hood and 2 xp3000's in the back with 6 runs of 1/0 knu kca front to back and dual inputs in the amp with 1/0 kno kolossus and I drop to low 12's-high 11's within 30sec of playing full tilt, but I still havent put in my 350 amp alt yet
Used to have a loud truck
he will need 3 to 4 batteries.. sundown suggest 3 to 4 d3100 on a sa4500d and its rated at 4500 watts, so how will 1 d3100 be enough for 6000 watts
ok error on my part i read your parts list wrong. yeah you will need more than 1 battery for 6k for some reason i was reading it as 1500 watts. dont know where i got that from. anyways.
if you want to play with the vehicle off maybe look into xs power's XP series.
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
I looked at the XP series and the battieries i mentioned above put out more amps then the XP series. But since everyone seems to think i can run the BTLS with that much power on 2 batteries, im glad i ordered that. I was thinking of putting a red top battery where the car runs off that power
I would really like a definite answer on the amount of batteries one would need to accomplish such an adventure
there is no way to know for sure before hand.
you may be wired to 1 ohm nominal but you may be rising to 4 or even 8 ohm pulling alot less amperage
i have ran 7k on a 250 amp alt and a single 70ah battery and didnt drop under 12 volts, after i put all my batts back in (500 ah total) it doesnt drop under 13 volts.
getting a good alternator is the best first step. if you are only pulling 150 amps off a 250amp alternator your batteries will never be getting pulled from. only once your voltage drops below your batteries resting voltage will you be running off battery reserve.
and if this is a budget build you may want to look at other brands i run c&d batteries and paid under 400 for 500 ah of batteries.
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
I stopped calling it a budget build since this is what I want. The car audio shop in my town is doing it since im deployed and wont be able to. but i dont want them ordering anything and charging me extra for the orders. which is why im trying to get everything squared away now
  • Who's Online   0 Members, 0 Anonymous, 945 Guests (See full list)
